In order for the subtitles to work, and not play the one from the previous show, the subtitle data needs removed. I found the data, but there are no delete options in Cinema. Is there a place on firestick to remove select data, without having to delete all data, which requires resetting account info and preferences?
Welcome to the community.
If subtitles are always on try turning off all cc options and use mx player or just player if there is subtitles you can select the text icon top right area and turn off subtitles. If they are hardcoded you cNt turn them off
