Cinema 2.0 and Real Debrid Not Working
Cinema made me update to 2.0 and not that I did no rel debrid links are not showing up as with the 1.x version. Under settings it says I’m logged in with Real Debrid but stil no links.
Ok. If you have IPVanish, make sure you disconnect it first, then log in your real debrid on cinema, then go back and connect your IPVanish. That’s what just worked for me. I hope that helps. I literally just set up my new tv in the bedroom, and connected my firestick to it. I just had the same issue.
Yea same problem here it show’s you signed in and no links come up. Just have to log out and log back in.
