Tried to load Chains tv. I followed instructions, got Chains but not Chains Tv?? What is the problem?
Glad I’m not the only one…
Having the same issue. The zip file uploads. Run install from repository. When you open the Chains Repository/Video Add-Ons, Chains TV is not listed
Yep… same problem here also.
Yup, same here. Chains TV sounds like a great addon, I hope it is restored to the Chains Repository soon.
I had same problem and tried it 2xs
Same issue with me. I tried 3 different times following Troy’s video making sure that I had the URL correct. After installing the zip file, then the repository, but I don’t have Chains TV in the list. I have the exact source before and after where Chains is supposed to be. I guess I will just go back to a Kodi build. I haven’t had any issues with installing a Kodi build.
I’m unable to install also! After three attempts, I just deleted the files and quit trying!
