Does anyone have a fix to correct tivimate 1 minute only recording?
Sup Schulm, welcome…
Heres a little recordng criteria…
No buffring…
More than 1 connection from yor provider…
Space on device (its recrdg in hd so it eats space very quik)
So u might need extrnl storage
Make sure its directed to proper storage file
& i think some providrs r bttr than othrs at recordg
hth…
What I have done is using a UGREEN USB 3.0 Ethernet Adapter Hub with RJ45 10 100 1000 Gigabit Ethernet Converter LAN Wired Network Adapter 3 Ports USB 3.0, Amazon.com connected it to my 1gb LAN via ethernet which improves my speed and cuts out most of the buffering. In the 3 USB ports I have a 32gb Samsung USB stick, a 128gb SanDisk thumb drive that I have formatted to us 10% for additional internal storage and for the 3rd slot I have a wireless adapter to use my remote keyboard. I see that UGREEN now have an upgraded model at https://www.amazon.com/UGREEN-Port-Gigabit-Ethernet-Adapter-dp-B0956BLF4S/dp/B0956BLF4S/ref=dp_ob_title_ce.
Yeah Muff…
I got a few of those setup, but i used the smays brand instead (both good)
