Can there be too many addons
I’m really looking for streamio/numio, but addons are discussed here.
Why wouldn’t you install EVERY addon? Is there a performance reduction?
The main reason is, there aren’t that many scrapers, and most of the addons all use the same ones, so it makes them redundant. Also I put it this way. You want Chips(sources) and head to Walmart. When you get there you see the isle full of ppl(scrapers) so you have to wait until the ppl in the isle clear out so you can get your chips. Very basic explanation but gets the idea across.
Too many add ons? Good question. Rule of thumb is if you’ve only got between 8 - 16 gbs of internal memory, you really can’t have more than 2-3 streaming apps without running the risk of bumping up against the limits of your device, particularly on devices with a lot of bloatware you can’t delete and get rid of. That will cause freezing and buffering for sure. As a minimum, get devices with a minimum of 32 gbs internal memory and 3 gbs of RAM and you’ll avoid these problems.
Hey @sim_bill I think this kinda misses the point. You can indeed have to many addons and especially with several of them trying to scrape for the exact same source, forcing a potential problem with queuing which in turn forces multiple repeat attempts after failure, and is completely unnecessary. Using a few good addons will give you faster results and get you sources quicker. Even in DuckStreams where I can load a bunch of addons and indeed had 12 good ones at one time I found there was absolutely no advantage and trimmed it down to about 4 inside Duck and outside I have Debridio OC and PM. I find that from the time I initiate a search to the time I have the Source scraped, loaded, and running is about 7 seconds now. Not sure having as many streaming apps as you have space for has anything to do with it as you are only using one app at a time. I do agree that these days I personally would recommend a minimum of 4 GBs of RAM and 32 GBs of internal memory, the Ram being the most important for running the app and scraping. Have a great week.m
Agree that having at least 4gbs of RAM and 32 gbs of memory storage makes things easier. If you multitask or use a multi screen option on your device, the difference becomes more noticible.
Multi screen Isn’t VOD and not using addons. It’s live TV. If setting up Multi screens then that’s usually a Desktop computer and not a streamer. So then it’s a matter of knowing what you want to do, how to accomplish it and what equipment you need.
I went from 7 add ons to three. Everything much faster and I don’t get stuck on the endless rotating gear anymore! Cheers!:beer_mug:
You are always welcome. Glad I could be of help. Don’t hesitate to post any more questions you may have, they help many others not just yourself. You’d be surprised at how many ppl have the same concerns as you but are afraid to ask. Have fun and STREAM ON.
