Can I use MC COOL on my fire T V?
MY Fire TV keep telling me to remove apps. Is it possible to replace the Amazon with MC COOL and will I gain more space?
Mecool boxes will work on any tv with an HDMI port. Depending on which model you are looking at, it should increase your storage without a doubt.
AMD237
Thank you for your reply
If you need help deciding which box is right for you, let us know. A decent amount of us have a Mecool box, so you can get first hand user feedback.
