Can someone tell what the best cache settings are for Stremio ? They are No caching , 2GB , 5GB , and 10GB for watching real derbrid links with Nvidia Sheild 19 Pro .
I don’t use a buffer in Stremio at all. If you’re going to, then start out small and see if you have any issues. I never have one and use RD links as well, and just the rare buffer.
I didnt think adjusting this would really benefit much for those with a really good setup. Powerful device, speedy internet, solid vpn, etc. As always, you could trial the settings and see if it makes a difference, but I believe normally those settings are for less powerful devices and slower internet speeds.
Ive got a shield running stremio with rd and runs fine.
