I’ve used Digzz Xenon builds for years now. I used to be able to install sources other than those that come with Xenon. Starting a while ago there is no way to add my favorite add-ons. Each update removes and replaces those that were pre-installed! It keeps changing, and not with the add-ons I want. I’m fed up with that limitation.
I’m using the debrid version (Xenon Plus) and would prefer a build that also is debrid only.
Do you not use the utility in Diggz to save data … favorites etc ?? I update and it just takes existing repositories and addons over to the new updated build.
The only repositories that function are the ones that are pre-installed. I’ve gone through the steps to add new sources but, in the end, they do not function. If you go to Configure them, the info at the top right says it’s not allowed.
I’ve been able to add The Crew Wizard into my Xenon FREE build. I’ve added to this build global Real-Debrid and TRAKT, and it’s behaving very well, so far.
I see your Skeleton Crew (v1.2) is of the choices in The Crew Wizard. I’ll be sure to test it once I’m done playing with the “enhanced” Xenon FREE build.
Lol. That’s just because I contributed a link to the Skeleton crew as I had it at hand, not because I know anything about Kodi or contributed any information other than a link, personally I can’t stand it.
