Buffering with Stellar SreamZ
Started using Stellar StreamZ over the weekend and have nothing but issues with buffering. Any suggestions on how to fix this problem?
Assuming you have a good internet connection and bandwidth, I would report the streams giving issues to them. I’m also trying them out for a month and I won’t renew since streams continue to buffer for me as well.
@BillWall
If you are at 30+ down speed then you should be good.
Get free trails of others and try them it’s probably your provider. Report it to them as well.
Not everything will be perfect.
I’m very reluctant to use any product where the developers are to lazy to update their own info. They recommend using filelinked to install their stuff. Ummmm ok, it was shut down some time ago. Now what?
If you find one that doesn’t buffer. Please let me know and I’ll do the same. Thanks.
