BitTorrent and UTorrent
Ok. These are torrent sites. Questions: Are they the same? If not related, is one better than the other? Use Both? I guess I’m looking for some information on these. And of course Q bit Torrent (a client site) TNX for any info.
Bit Torrent and UTorrent aren’t sites they are torrent downloader/creater apps. They can also be used to create and upload torrents to a site if you’re an uploader for that site. I’m not going to name torrent sites here as they are still a grey area for ACE and other gov enforcers and have been for over 25 yrs.
@Ralph
They do the same thing essentially.
Those are torrent Downloaders you get from torrent sites.
Mentioned above.
If you go down this route I highly recommend a encrypted torrent Downloader like deluge and use vpn socketing
Thanks for the info and I tried Deluge and it looks pretty good.
@Ralph
It encrypts the user pool and all the data including the seeders.
So that way people can’t piggyback that info when you leeach from that seed pool.
