Best Real Debrid Alternatives for Reliable Streaming
RD working here now.
Fen light should be same results as Umbrella. They both updated to get RD.
I see what you mean now for some movies…not all. ā€œUncheckedā€ā€¦interesting. They play fine as well.
Not seeing any working RD links on Cinema, BeeTV or FilmPlus. Still some on Stremio.
Has anyone been able to include the premiumize into a build yet. It is working just fine w/umbrella as troy prescribed!
The Diggz builds have always given you the option for Real-debrid, Alldebrid and Premiumize as part of the Account Manager it uses.
I switch over to Prem without issues.
Thanks for the reply. I too, disabled RD(Fen addon) and, added premiumize and it’s back showing my shows again. Kinda slow but working. Enjoy your weekend!
Cheers for the info.
If you go to Account on Premiumize website you can select a different server.
You can test to see what is fastest for you. That should help with speeds if you find a good one.
I think, and only think, most of US is sent to San Fran as a default location. Probably the big influx of TP uses in US overloaded the servers.
I can’t pull up a lot of shows and episodes with Premiumize, signed up for a year kind of wish I didn’t. Hopefully improves over the next few months since I have it for a year.
What are you looking for? i can try 1 or 2 to see if i get results.
I havent had a problem yet. But i havent dug deep yet.
Yellowstone season 5 episode 9
Yup got it. ā€œDesire is all you needā€ is the title. There was only 1 4k and a few 1080. 29 total links including 720 and sd results
I am using kodi with Coalition. Not sure if that matters.
I got a year plan on alldebrid and it does not work for me… so I went a head and purchased 3 months premininze and that one is working, I was getting so frustrated yesterday :upside_down_face:
Yeah I’m using Syncler maybe different scrapers. I usually only watch 4k links. I have AT&T Fiber paired with surfshark VPN. I was able to to find on Streamio.
Just got a refund from Real-debrid. Said they are refunding only because of circumstance. Have to send a refund request
Which is better to use?
I took premiumize , but noticed later that All debrid is much cheaper
Stremio has around 30 links with at least 2- 4k on real debrid
Different adopters of each service seem to get different end results, as each user’s blueprint for what they’re using the service on varies (Kodi, Apk, VPN or not, etc).
Have you read Troy’s article on his assessment between the two? PM and AD are discussed in top 2 alternatives in the below article.
  • PM more expensive than AD, but better payment options.
  • PM gives 1000GB cloud storage for downloads.
  • PM has a limited metered allowance use.
  • AD may not coexist well with VPN.
  • AD business based in France, as does RD. Unclear where their server(s) are based.
Both offer free trials. You should try them out for test spin and come up with your own conclusion, base on what your priorities are.
** Apparently PM states that they no longer offer any free trials due to heavy abuse.
AllDebrid is working for me but not as good a RealDebrid was (fewer streams).
