Best Real Debrid Alternatives for Reliable Streaming
Does that premiumize work well?
Troy mentioned Alldebrid is not VPN friendly, does that also apply with Premiumize? Thanks
Hello, Premiumize is working great with Surfshark as you can see in this video that I uploaded today.
In all fairness, that review we did on AllDebrid was awhile ago and things may have changed. I’ve always wondered if AllDebrid was owned by same outfit that runs RD so that’s another reason we are recommending Premiumize.
premiumize isn’t working for me. It provides a list of sources in blue/purple. Each source shows premiumize. I click on any of them and get the message: “One or more items failed to play. Check the log for more information about this message.” Any idea what is wrong? I disabled and removed Real-debrid.
Just as good if not better than RD. I’m getting more 4K links with Premiumize.
Are there limitations on how many linked devices or simultaneous connections with Premiumize.me?
I know with RD you could have as many as you wanted but you could only play from 1 location ay a time. But you could use 3 different devices at the location at the same time.
Isn’t that a Kodi error message? Could be something to do with Kodi or the addon, rather than the debrid service(?)
now it doesn’t load any sources. no stream available. good grief. wtf is going on?
Will Premiumize work with strremio, that is the apk I utilized with Real-debrid?
problem resolved. i cleaned the settings file: Umbrella and fixed blank settings: unbrella. Then I had to re-enable coco scrapers as an external provider.
I must say, premiumized takes a lot longer to start the video stream than real-debrid.
the caching really sucks on premiumized. it stalls quite a bit even without using a vpn and high bandwidth link.
Same here, just activated premiums and I get links then failed code or it starts to play but massive buffering!!
Yes i think it may be slow to load the playback right now because they are probably getting a bunch of new members all at once. They will probably need to upgrade their system soon. Not really sure what that entails but lets hope it improves.
My guess is they werent expecting or ready for the TP rush. Lol
I just got the Black Friday 3 year deal and nothing will play!! Either failed error or frozen!! Don’t understand, I did everything right!! argghh
Ive gotten links to play but more recently tonight its been very slow to play.
Maybe someone familiar with what these services need to provide fast reliable playback can explain to us.
I’m just hoping its a temporary setback while they expand their capabilities.
All the links come up on all my Kodi add ons but nothing will play!!
Guess I’ll try to get help from premiumize??
Let us know what they say, and if you can, let them know you are not the only one experiencing the issue.
Don’t know about ownership but until last week I used all debrid with ipvanish, I switched to Surfshark this week and it has worked fine with both. I’ve not had any problems with the service
I will and have just emailed them. Using Surfshark, like I said all the pretty purple or red streams come but nothing will play. I’ve tried 6 different add ons and none will play or start then just freeze!!
