Best Real Debrid Alternatives for Reliable Streaming
Make sure that you have Coco Scrappers on Fen and a4k scrappers on Seren still installed and the Kodi provider setting turned on.
Go to TP’s Fen Light or Umbrella instructions to check about Coco.
It’s similar instructions with a4k and Seren.
Contrary to the rumors RD is certainly not done. I’m getting tons of RD streams on Umbrella
RD is still working for me, too (mostly on Stremio/Torrentio). But at about 30%-50% of the streams it used to get. Not sure why this is as I’m getting both RD and RD+ links, just a LOT fewer of them. I’m even finding non-debrid links on Cinema that I’m not getting on Stremio/RD (links that I’m sure I would have got previously).
Tempus Fugit!
I’m having no problem playing RD stuff on Stremio and Syncler. But I am pretty sure everything I am watching was already cached before the takedown notice.
what’s RD+?
I’m getting good RD links with CimenaHD too.
RD+ are cached links and those will be disappearing soon.
Yes it’s working fantastically
How did you perform a speed test for fastest streaming on Premiumize Me ?
Select change location as shown in the first pick, choose a location and run the test.
so is real debrid working or not and should i renew please
Yes, and it’s up to you.
thanks
Streaming apps that utilize RD have been making their adjustments since the mess all happened. Syncler working well now (after new update), a lot of Kodi add-ons working with it as well. Who knows how long it will last, but that is the risk we take with just about everything we enjoy about cord cutting.
Just started using Easy Debrid and for me is working just as well as Real-debrid.
Don’t forget to use code
XMAS24 for 10% off yearly price.
Consider just short term renewal terms, rather than >6 month terms.
Worst case - small dollar(s) losses.
…just don’t be asking for refunds. :hugs:
has anyone tried Put or tor box with Cinema ,Beetv or teatv.? Did they work or what would be the best one to use?
how are you finding easy debrid so far. I’m trying to find the best one for Apps like Cinema ?
Been using on Kodi and Weyd and having no issues at all.:+1: As far as I know, Cinema hasn’t add ED as an option.
I just might have to finish setting up kodi, I have no idea what Weyd is. I like Cinema and it’s to use parents find it super easy.
some links are working for me I used fidlity points 1000 for 30 days.
