Best Real Debrid Alternatives for Reliable Streaming
You average less than your daily point refresh, so I would rarely worry about your fair use points based on your consumption habits.
Stream on and have fun.
For sure. I use Kodi add ons Umbrella, Fen Light, and The Crew. I also have BeeTV and CinemaHD for a last resort. Im located in PA and use a VPN (Surfshark) and i still canā€™t get any feeds today. Ive seen some peopleā€™s RD is working, but its bkt working for me, and ive switched to different ipā€™s. How about you?
In step #4 there is no zip file showing so I cannot go any further. This is happening on my Skystream 3. I did it 3 times naming the file Umbrella 2 and 3 with same result.
I did the same thing the night before on another TV with a Fire stick and had no issues.
Thats strange. Have you tried to install a different addon or a build?
It sounds like its a device issue. But i am not familiar with it to know how to help.
All my add ons on Kodi now have RD links. Except coalition and pov. Dradis, crew, infinity, umbrella, fen lite and cinema all working . Just fyi!!:grin:
Hey I tick., I run ipvanish, and run it on san jose or lasvegas Nevada. It goes to the fastest connection. You may try those ip servers? I havent tried Kodi and RD today, but it worked well yesterday. Knocks on wood!
Same here, as Cody I run Ipvanish, and run it on San Jose or Las Vegas Nevada on Stremio and get RD links.
Yes, I know, just trying to figure this out for the future if neededā€¦thx
You will be fine my friend!!
Sorry to be so dumb ā€¦I got a refund from RD. I signed up for three months with Premiumize. How do I get it on my Stremio? Iā€™m not using any other apps like Cinema, only Stremio. Thanks ā€¦
You need to configure addons like Torrentio and add your PM to it. Oh and please donā€™t say youā€™re dumb. You arenā€™t. You just havenā€™t learned yet and I have no doubt you will. If you still canā€™t understand then by all means PM me. Iā€™m here to help.
Thatā€™s a mail drop address.
Whatever addon that youā€™re using on Stremio, youā€™ll have to configure it by copying and pasting your PM API key (available on your PM account page, under your account settings) to the stremio addonā€™s configuration. Itā€™s similar to how you added RD to it.
This is done easier on a desktop PC or laptop, rather than your mobile device.
Thank you ā€¦ I have done that but itā€™s not adding Premiumize to the addon.
Iā€™m using my PCā€¦
EDIT: Itā€™s now working ā€¦I think I added the addons twice. Having removed one of the addons, the other now has Premiumize on it. Thanks you for the help.
