looking for the best add on for older tv programs (2000-2017) using V19.3
also will rising tides add on work on V19.3?
What happens if I don’t have a real debird? will it still work?
If you dont you will be limited free stuff goes fast. You are probably better of with stremio if you don’t have real debrid.
OK thanks for the info
Many add-ons are no longer compatible with kodi older version, many devices as well. If you decide to upgrade here are few links to consider from TP manuals for the best add-ons Real Debrid also VPN discount. If you need further assistance just post your comment.
Best Kodi Add-ons
Real Debrid
IPVanish VPN Discount
Yes rising tides works on 19.3, but you need a VPN if you’re in the UK , i use it for soccer and set it to France or USA.
