Before I look into this service I have a couple of questions.
1 - How many devices can be on one accountā
2 - What is the cost for 3 months and 5 devices?
Get a trial - price $20 - $35 yearly subs depending on service.
Amber sells 7 different services
Most are one connection - nothing to stop you getting multiple services or multiple subs of one service - my take multiple services in case one has an issue, you have back ups
Re devices
Free to install on as many devices you want but only use one device at a time with one sub.
If you use all 5 devices at the same time, you need 5 subs.
Thanx for that update. I had just signed up with them and then it died.
Just tried the trial. WOW overwhelming amount of channels, shows and movies.
Problem is none of the EPGās Amber have me work in Tivimate. Iāve got similar problems with Apollo - frustrating to loose guide info. What EPGās work with Amber & Tivimate?
Yep, the EPG in Strong8k is minimal, but as others have commented, getting MYEPG for Strong8k has changed that completely! Also, if you donāt use crypto (which is how MYEPG wants payment/about $6 usd per year), they have a payment option for Revolut which is easy to setup and use for payment. ![]()
Hi Amber I would like to Order Strong K8
Hello, this is not how it works. The very first post of this very long thread explains how the process works. Basically you create an Alibaba Account then message Amber on her Alibaba page. She will give you a 24 hour trial. If you like what you see she will send you payment instructions for an annual subscription. But you canāt order from this site. Iāve attached a link to what you need here
And as ALWAYS, step #4 is VERY Important ! ! ! !
I now use Strong and Trex and I like Trex better because of the catch up options.
Does trex buffer much? And how much does 1 annual connection cost?
@BigGag I have Strong and my neighbor has Trex. Since you have both, I wonder if one buffers more than the other and please share how dependable you think each one is. Thanks. Buffering drives me nuts and Strong is pretty good overall for me.
This may not be popular, but I bypass TiviMate with my VPN through Surfshark. Since doing that I have little to no buffering. I do use VPN for all other apps such as Syncler, Stremio, and Nuvio.
I used to have surfshark on my ASUS router using VPN fusion option, but it started acting up recently.
As far as costs are concerned, both Strong and Trex are very reasonably priced (under $40 year for each). I have both because I like to have a back up options and I do pay for myepg for both services that fills in a lot of the electronic program guide (epg).
I have a third service I use that used to be Lemo, now itās East Coast Flix and its around $120 a year for 2 connections. Iām not sure Iāll renew when subscription expires next month. Iāll probably try another service from Amber Baby.
I use her Mega. Had to get new url couple days ago but she responded in 5 minutes with one.
Got it, donāt mention IPTV. But can I ask how many connections the service has/can I pay more for additional connections (a package, not separate subscriptions)? And what other services she offers?
@mantaray82 Generally, each service is 1 connection for the money. A few (Mega I think) offer multiple connections on the same account but I donāt think there are built in savings per connection as you level up. For Strong, Trex and most of the rest you just buy extra subscriptions with different logins for additional connections. Others can chime in if Iāve misspoken.
I donāt know what else she sells other than 7 or so IPTV services. I have Strong and I like it for the $$$ as a backup. .
If your ISP is one that does not sell cable you may get away with that. I for one, do not want to take the chance so itās VPN on for me for anything IPTV. Good Luck with your setup and keep us posted on how it goes please.
She said Mega is the only one that is available on a shared login, and has a max limit of 3, priced accordingly to amount of feeds purchased. Recently received pricing of all that is available for 1 year sub.
If you get in touch with her using telegram ( I think thatās what itās called ) or Signal, the text app, you can talk about anything, on the Alibaba site Iām not sure what is ok or not ā¦so, others can chime in on this ā¦
