šŸ„‡ Best IPTV - Wholesale $2/mo & Alternative
This error means there is a cache issue on your device.
Clearing cache should fix issue
That’s what the modded TiviMate person said, too. I did that. No change. I uninstalled and reinstalled. Still no change. Then they tried telling me that Strong was having a global issue. I knew that wasn’t true because my login info from Amber was working in my other app. I just had to drive to town to get a different app for her login info to work before the game started.
I have Strong in Ott Nav and it is working well, and Amber’s Mega in Sparkle and it is also working. As for the modded apps I only have the Tivimate version for the one private service I use, it is on one of my boxes to save on my 5 devices.
It’s a bit of a process. If you ask ChatGTP, it will give you the steps. The most important step is not to close Tivimate. I got it to work.
In my experience the data source exception means the channel has not been activated on the suppliers side.
Here’s a link to an older thread here on TP there might be some info there that will help….or not ….
welcome and hello on Make a GIF
I create 2-3 different playlist from the same account going to different servers so if one playlist does not work I will go to the next play list also I will load the same account into a different apk double back up
@JackyL using modded Tivimate that has Server URL built in. He will need to use another IPTV player where he can input the Server URL.
I’d like to ask a question. What is the total setup I would need to do this? IPTV, then what? I am very noob to all this still. Thanks in advance!
You would need an Android streaming device (I’d stay away from the Firesticks). Lots here use the ONN 4K Pro (Walmart). And you will also need an IPTV player. Tivimate Premium seems to be the most popular player here (can get in the Google Playstore and I think Troy’s Toolbox as well). That’s pretty much it
Thank you every one for your input. Yes I tried different apps without the built in URL, and strong8k
works.
Found this on Reddit……
Strong 8K Apps - Updated 30 January 2026
UPDATED 30-JANUARY-2026
Here is the list of apps provided by Strong 8K as listed on their reseller panel.
There is no URL required, only your username and password.
Do not ask ā€œwhat is the differenceā€. Do your own homework and test them out.
You will need to figure out how to fix the apps listed as URLs are prohibited on this sub. Anyone deciding to ā€œhelp outā€ by reposting any of the links after ā€œcleaning them upā€ will be permanently banned with NO chance of being reinstated. Consider this your warning.
If you are presented with two options (one is ā€œcloudā€), try each one. Some will need ā€œcloudā€, some will not. This is dependent on your ISP and whether or not they are blocking OTT services.
You may or may not ALSO require a VPN. Again, this is ISP dependent.
If you want official support for any of these, contact your reseller who may or may not help you. This sub is not operated by Strong 8K - we are all just here to help each other out when we can.
Use them or don’t. This is only for your information, for those not wanting to (or able to) purchase alternate software.
App Downloader Codes:
App Name Code
Fast 8k Player 948558
8k Player Vip 439873
Strong Power 109173
8K Player VOD 479984
8K Player Plus 1240465
8K Player Vip+ 6883465
8K Player Prime 1050263
TiViMate 8K 6762447
Web Player - http (:slight_smile: //web - 8k (dot) me (not working at the moment)
Smart TV App For Samsung and LG - http (:slight_smile: //smarter8k (dot) ru
Smart TV App For Samsung and LG - http (:slight_smile: //smarter8k (dot) su
8K PLAYER macOS - http (:slight_smile: //download (dot) best-ott (dot) me/apk_gold/8k (dot) PLAYER.OS-1.0.0 (dot) dmg
8K Player Windows 10 App - http (:slight_smile: //download (dot) best-ott (dot) me/apk_8k_win/8K.Player.Setup.0.2.0.Windows10 (dot) exe
8K Player Windows 11 App - http (:slight_smile: //download (dot) best-ott (dot) me/apk_8k_win/8K.Player.Setup.0.2.0.Windows11 (dot) exe
Locked post. New comments cannot be
Anyone having issues with the M-Tivi app (Used for the Mega service) uninstall and reinstall the app.
I don’t know if AB can help me as y current provider has me spoiled with a bunch of 24/7 channels.
Currently, the service is starting to suck and I have about wo weeks left before I decide if I want to renew or not.
I read above about a service or something that has a lot of 24/7 but it’s late and I don’t feel like going to look for it.
Anyhow, I hope AB can come thru,
I have her Strong 8K and see there are 24/7 channels in there. I don’t watch 24/7 but you can always ask her for a trial of any of her services and decide for yourself
Trex has a ton of 24/7 ch’s also
I have Strong from AB as a backup to the private service I’m on. I’m always checking out different services. Vortex has a nice 24/7 selection and the epg guide is populated which is a big bonus for me. I may re-up after my month is up. I can’t remember if we can post urls to these or not. DM me or just Google Vortex IPTV.
I helped my neighbor get TREX and we are getting blocked. Does anyone have a few TREX URL’s? I sent AB a message but her webcam shows her in bed sleeping.
Joking! It’s middle of the night there.
@sea157 I had the leadervpn URL crap out on my Mega. Thanks a bunch for this! I also found another working URL. I can verify that all 3 of these work.
http://bucgquqz.mossaptv.com
http://amjiqucj.mossaptv.com
http://amjiqucj.meza.in
