I watch their Team feed when theyāre playing.
Most of the football feeds in 4k60, Iāve found to be only in certain local market channels.
For example, I didnāt see a 4k feed in my local market for a game, but switching over to a different CBS market, it was it.
Iāll watch my Favorite team up until the 3rd qtr and then switch to Red Zone because there is nothing more exciting than Red Zone for the last 45 minutes of the early 1pm games. Red Zone is not 60 FPS on Strong but you can find 60 FPS for the individual games. I use this to see what local channels the individual games are on and compare the quality to the games in the NFL category in Strong.
Thanks @Miki
absolutely correct ![]()
Any services that have working M3U currently?
I have Layerseven but M3U isnāt working through emby server or other apps. I also tried a trial for Stong 8K but it didnāt work either.
Layerseven doesnāt say much except that it will be restored eventually.
Everything works reasonably well through Xtreme.
FYI: Mega been pretty solid lately. Has RedZone in 60FPS and all the NFL games can be found in HD 60FPS. One thing Mega has over Strong is Catchup feature although Catchup only works on some channels. Catchup works good on the cable news channels.(Fox, CNN and MSNBC).
I thought you could convert any Xtreme login to M3u by using this template and replacing your Xtreme credentials? It worked when I was trying out IPTV in Kodi, but I havenāt used that in quite some time. Worth trying.
http://serverurl.com/get.php?username=usernamehere&password=passwordhere&type=m3u
I am at the end of my 24 hour trial with ab. I am getting NO epg information. The indication I get from messaging with her is that epg is a hit or miss proposition and a lot of her customers use it without epg. Without āelectronic program guidesā I find all the data stream basically useless. I must be missing something. I am a novice to IPTV and I realize I know very, very little about the ins and outs. I have searched but have not found this particular topic discussed. Help?
There are various free EPGs available like
https://github.com/iptv-org/iptv
There are others that have been listed on here.
Or you can use a paid version.
I use https://myepg.top/ with Tivimate and it fill in most of what I want. There is a free trial if you scroll all the way down. It is purpose made for services like AmberBayās, just pick the one to match.
Just to note the EPG wonāt fill in the 24/7 channels and the streaming service channels usually have an EPG on the first channel in the category.
This is a copy/paste of a post I made previously on how to add it to Tivimate.
If you are willing to pay or donāt like to tinker to make things work, then I would recommend https://myepg.top/ it is pretty turnkey for the major categories like entertainment, movies, kids, and many sports.
The paid version is 5,90 ⬠a year but it has a free trial if you scroll all the way down to the bottom and click on the guide you want, in this case Strong8k. Unfortunately, since there was so much abuse you have to go through a checkout process without payment, so you have a private link.
For Tivimate this is how to add, other players will be a little different.
After checkout go to myaccount>downloads and right click on the link to the guide and copy it to your clipboard or do the same on the free EPG link you want. Hopefully you have a device you can connect to your TV/box so you can just past it because it is a long link to type out. It Tivimate go to settings>EPG>Add Source and add the URL from your clipboard. Then go to settings>Playlists>Whatever you called Amber Babyās playlist>EPG sources and toggle on the new EPG. You can leave the default on also in case one goes down. The first update usually takes a longer time than normal but should eventually update.
The paid one should auto assign all channels. Sometimes on the free ones or even the paid ones you have to manually assign them. Even the paid version doesnāt have EPG for everything like 24/7 and some of the channels pulled from streaming services etc. Sports depends on what you watch etc. The only way to know is to try different ones.
Whether or not it is worth paying for depends on the channels you want the EPG for and how important it is for you. The paid version allows you to request channels in the telegram group. The link in on the main page and you can ask any question there.
I have been using Strong from Amber and it works well in both TiviMate and Sparkle, except I donāt seem to be able to record to Shield external storage with the 1 connection she offers. She said Strong is only available with 1 connection, so has anyone had good experience with a similar provider who offers 2 connections?
EPGs have been discussed ad nauseum. There are lots of solutions. I would say that with a little effort ABs playlist can have about a 90% complete EPG using many free sources or if youāre so inclined some paid ones. To add to those provided by @ScoobyDoosSpots
Amber is a seller of this service - it doesnāt matter which seller you get Strong from - they can only sell one connection accounts - you can buy multiple accounts.
Re Recording
You should be able to record the stream you are watching - check that you have setup the storage for the recording correctly
What I have found from Strong service is multiple source stream of same channel - Raw / HD / Hevc etc
I think one of these options will have EPG - find these and add them to your fav list
There are groups which have an INFO stream - this will show what is playing in that group - eg HULU group
I donāt think you will ever get to 100% EPG with IPTV, but Adding on to what @ScoobyDoosSpots said I also use MyEPG.top with ABās Strong IPTV and it filled in a lot of the EPG holes
@Smokeballā¦.i am far from having the knowledge that those that have answered you posses, and they have all offered solid help, but i have been around the streaming block 6 or 7 times and find what @SoloWarrior said āI donāt think you will ever get to 100% EPG with IPTVā to be true. while not an ideal outcome, it is not a horrible situationā¦.and FYI we were all beginners in the beginning ![]()
Thank you, ScoobyDoosSpots, thatās just the information I needed and another good example why being a Patron is such a good deal ⦠people like you. ![]()
So my Strong 8K is out from Amber Baby. Anyone else having an issue?
Up and running here. ![]()
All channels on mine says: This video has been restricted. Streaming video from Cloudflareās basic service is a violation of the Terms of Service. Please visit cfl.re/tos to learn more.
Iāve changed VPN location and also switched to a different VPN. Other IPTV service are working fine.
