What is your Main?
If you are a reseller you will get access to the providers Telegram channel.
Is Strong 8k the best one to get? What are the other options
Try these
FYI: Anyone that has Mega using MYEPG, you will need to login to MYEPG site. You will need to select Downloads and copy the WORLD.GZ link Old links arenât working any more. MYEPG site now has a Shorten URL link too.
Best is gonna be subjective, as what makes me happy may not do the same for youâŠ. but Amber offers 5 different services, with a free 24hr. trial for each one. others may chime in here an say what they like or dislike about a particular service or already have. As you have time start reading at the top of this topic and get some cluesâŠ. Good LuckâŠ.
Red X. Iâve had it for 5 years itâs pretty good, but stuff happens from time to time and Iâve never wanted to pay for 2 services until I found this $35 a year Strong 8k
Shuggy posted services sold by Amber
Do any of the listed services have 5 connection option?
And Please everybody, Remember this is very IMPORTANTâŠ.
In the chat ask Amber Baby for Strong 8K. Do not mention the word IPTV in any communication through the ali website. She will also provide you with a trial if you want to test before buying.
Amber 8k: sometimes it works, sometimes it doesnât. Is the solution just to change the url? How does that work for xtreme code?
I know the service is cheap as hell, but a bit of stability would be nice ![]()
Whatâs the difference between all these services? Is there a description of each somewhere?
Some users using vpns can sometimes have to switch location server IPs. If youâre getting no channels thay load, disconnect and reconnect with a different IP and see if channels load.
The cf-hi ones wouldnât work at all. I got the hi-world to workâŠ. For nowâŠ..
I donât use vpn
This one works for Amber 8k
Has anyone tried any of the Strong APK apps? I see some floating around. Will they work with Amberâs strong service? Just plug in your username and password? Does it work?
You do not want to do this - many use paid apps with multiple services like Tivimate or MYTVOnline 3
At new members wanting to try, contact Amberbaby via WhatsApp, Telegram or Signal +86 13973822150
Be patient, there could be a delay in her reply as she is in a different time zone.
Be nice, she will help when needed and let you try all the different services
FYI: Mega is offline due to maintenance. No update when it will be back online.
