šŸ„‡ Best IPTV in June 2026 - Wholesale $2/mo & Alternative
I wonder if some of the URL issues are DNS related. I would think that a URL should be good to go or not, but it seems like different users have different luck. I’m betting there is some ISP shenanigans involved and changing their DNS might help the ones where none seem to work.
I have had to change URL’s twice in the past 3-4 months or so not a big deal. I use AT&T Fiber without a VPN and I know they don’t play any games but could be DNS
Ittechbasics is not what it used to be. I just started a ticket last night with them. They got pretty quick with a few solutions. The xtream url has changed.
http://cdn-ky.com
http://kytv.xyz
I also had to change the vpn protocol to open tcp or open udh.. I’m not real sure that is the correct wording but I remember there were 2 different open ones.
I hope this helps you.
Try one of these 2 xtream urls I just got from ittechbasics.
http://cdn-ky.com
http://kytv.xyz
thank you very much
Anyone notice that Mega is not loading? It 2 am in China, so it’ll be a while before Amber can reply. Didn’t see anything on telegram
:police_car_light: URGENT SERVICE NOTICE
Some of our domains have been blocked, which is currently affecting service for some users.
:gear: Our technical team is urgently working on replacing the affected domains and rerouting the service to restore full access.
:counterclockwise_arrows_button: Most users will come back online progressively as the new domains are applied and propagation completes.
We sincerely apologize for the inconvenience. This issue was beyond our control, and we appreciate your patience while we work to fully resolve it.
MegaOtt-Team
Dang, I literally just asked AB for a trial tonight
I appreciate your response. I heard from Amber and saw the post on telegram
Anyone have luck with either of these? I’ve been using kytv.xyz for years with LEMO/KEMO and it’s not working.
Not sure what you mean by ā€œcustom favoriteā€ groups…you can certainly set up ā€œcustomā€ categories like ā€œABC STATIONSā€, ā€œNHLā€ etc, etc, and those are really just groups of ā€œfavoriteā€ channels. Easy to dowith a long press while in ā€œAll Channelsā€ā€¦
No issues for me last night during UFC event with one of the URL’s that Amber supplied last Friday. Hopefully everything working fine now for everyone.
If your MEGAOTT urls is on the blink,your reseller can now update it for you .
Strange that the original URL she gave me for Strong about a month ago looks nothing like these, except it’s a ā€œ.meā€. Been working great.
I bought from amberbaby last year in November and it didn’t even work for a month.
Then contact AB and get it resolved. Things happen; she fixes them. That is why she is loved by this board.
I have always found Amber quick to respond and extremely helpful.
If you are on Whats App I can send you her contact info>
It could be your VPN too.
Very possibly a VPN problem. I was using a Surfshark server in Bend (OR) and was getting ā€œUnknown Tuner Errorā€ on every channel; switched to the Latham (NY) server and all channels work perfectly. Not sure why that would be…anyone care to comment?
That’s one of the mysteries of the world, but I too am curious about this. I bet it’s a lot of factors.
Another thing to try is a static server – though lately the US servers seem pretty crowded.
