You guys are awesome, thanks
Who is Amber?
Deleted due to author snarkinessā¦
Thanks MIKEN. Think this is what is causing my problems. NEVERMIND did not work. Likely my NEXTPVR tool am using.
Does anyone know the URL format for the amber accounts, so that you are not using Xtreme codes?.
maybe Iām not understanding your question? Why would you not want to use Xtreme codes? The URLās you posted above are working
Itās my issue with NEXTPVR tool not working. The amber accounts work fine.
From the wiki page - Setup IPTV
Enter the URL (the web address) of a M3U file.
Request the m3u playlist url - Amberbaby will send it or you can generate it from xc info
Important - Strong service only has one connection - you can only use it on one app / device at any time no multiple connections
Apps like Tivimate / MYTVOnline already has recording options
Recording options on MYTVOnline app
Recording on Tivimate
Hey @MikeN , so watching while recording would be 2 connections, right ? not that iām doing that but good to know future referenceā¦.
Although Strong 8K might be advertised as 1 connection only I donāt think that is really the truth. A while back someone wanted to know how many multiview windows you could have open watching live sports before getting any buffering. I tested it and had 7 windows open before getting buffering. I did not realize this but someone told me each window is a separate connectionā¦ā¦So take it FWIW but it seems lke there is nothing within Strong 8K stopping you from multiple connections
I noticed that on apps with multiview - Strong works without issue streaming more than one stream. My thinking is, app connection is one connection
I had a friend who tried to connect with a second device and that would fail
interesting it is of popular opinion here that a 2nd Multiview window is a 2nd connection. Perhaps that is NOT the case?
thanx @SoloWarrior @MikeN butā¦.
this confuses meā¦.so if watching and recordingā-is that one device ? so it counts as one connection even tho 2 things are happeningā¦.
@itzme I have no idea I donāt have a need to record but you could test it out. I only know that opening several Multiview windows are possible on Strong 8K seemingly without any repurcussions or limitations
Nor do i, i was just curiousā¦.
Iāve also tried multiple Strong 8k windows in TiviMate without any problems - only had 4 though as that was all I needed
If one app is recording and streaming a different stream at the same time - Think that counts as one connection. Logic being it has one connection same as if it was displaying multiscreen
Think of it like an old Sat boxā¦. I had to have a box in the LR one connection, and the wife one in the BR 2 connections. Or another example is if I wanted to record a program and watch something else, I had to watch it while recording or watch something already recorded.
1 connection iptv in most cases means if you watch one channel and record another at the same time, that requires 2 connections. So if you like to record I would always advise getting 2 connections. Again some providers are more lenient than others, so ymmv.
And some will kick you from their service, only know of a few like that, but best to read the fine print.
