šŸ„‡ Best IPTV in April 2026 - Wholesale $2/mo & Alternative
It does say that, but doesn’t seem to be the case when playing the stream. I can do some additional checking.
There’s like 3 separate groups for mlb and 3 separate for nba. You have to do some searching. There’s also mlb team specific channels is the prime group I believe although not sure if they are back working. I can tell you this though, if you spend some time you can find almost any feed. Look also in the Canadian sports group and UK sports group, they show alot of American professional sports. When you find one in a group you don’t watch much save it to favorites or create another group. Its about how much time you want to invest to get your setup right. If there’s channels that repeat save the one with the best picture quality to your group.
I’m trying to message Amberbaby through What’s App but she doesn’t show up in my list of contacts. I tried searching her name and the number that was posted here but it comes up can’t be found. I’m trying to ask her for a private url. My strong is not working.
Any help will be appreciated.
Contact Amberbaby via WhatsApp, Signal or Telegram messaging app +86 139 7382 2150 for private URL
@comtech Amber told me they did NOT have private URL for TREX. Did you for sure get 1 and does it work? Let me know and I’ll reach back out to them. Thanks.
I’ve only ever messaged her on her Alibaba page and that is how I got my Private URL’s and she has been very responsive. You might try that
I contacted AB via WhatsApp and gave her my Strong and Trex login IDs and she provided the private URLs for Strong - there aren’t any for Trex (that’s not to say that there won’t be at sometime in the future)
Thanks for this information. I just got signed up. Quick and easy. Thanks again.
Grace Wilson
the one for trex is different than the one i was using and it works so i don’t know if the one i was using was original or not but they both work
@Thunderpants Many thanks Thunder.
On a different note, anyone recognize this guy?
She’s there keep trying !!
I’d never contacted Amber on Telegram before but did this morning for the private URL’s. I’m a little concerned that she gave them to me without having me verify my accounts.
Well if someone didn’t have an active account with a username/password I’m not sure the URL’s by themselves would be of much use. Maybe I’m wrong?
May not be one of her subcribers though is my thought.
Though this is certainly true, providing these private url links to unvetted subs could lead to unwanted public distribution of these urls.
These urls are only as effective as the control used behind their distribution.
Hi, I’ve had services from different companies but I just signed up here and I’m reading about different ones that I’ve never had. Is Trex, strong and 4k all from the same provider? I’ve sent a what’s app to AB and I’ve read she has multiple services. Are hers all different names? Thanks for any info.
@itzme This was a quiz for you to see why I put D Dawkins photo in the post.
Welcome! Strong, Trex, and Mega Ott are the 3 I have, and are different services. Amber sells all 3 of those services and a couple others I believe. Strong and Trex are pretty much the same thing.
