Which Strong8k player did you try? Were you able to get it from Downloader? I had problems.
The one that @MikeN posted in his message above.
I got it from Downloader but when I opened it a message said āsubscription has expiredā and it froze up. I understand that itās just a player and I need to load my log in credentials but having it freeze up makes it impossible. No sure what is going on with Strong. Getting a lot of mixed messages.
But itās my backup so not going to get too worried just seems thereās a lot of mixed messages coming from a lot of sources on what is going on
She messaged me to post here.
Took screenshots and posted.
She made a mistake - posted her private urls but asked to remove from original post and replace it with message to contact her.
You are free to use apps that you own including Tivimate
Re Strong apps from her post
I have never used them
Yes - private urls are available, just message her
Anyone else having an issue trying to use Downloader to try one of AB Strong8k players? I keep getting a ERR_CONNECTION_REFUSED error.
I sure hope to be able to continue to use tivimate. I hope in the long run this will make things better. I for one had no problem with how it was. It was no big deal. Iāve had strong for 2 months and only had to change 1 time. Even if I had to once a week idc, its easy. The community up here made it super easy. That said, it is what it is at this point. Whatever I need to do to be able to continue with strong 8k I will support. Its such a good value, the only thing I worry about is too many ppl getting in on it.
Happy anniversary.
Thanks for the kind words
Before I get a private url, I think Iāll wait until the process gets ironed out. Strong is also my backup, but the .ru URL crapped out. Are any urls on the short lists posted above working right now?
These are the current ones,
Just message her and she will give you the private URL
Mine was working today and I have the .ru URL. Iām just gonna DM her for a private one
probably would be a good thing not to post a private url from her on this site? just sayin
I have the same question. Strong 8K I just got and is so far much better than my old one that has been dropping the ball with sports. Iām still looking for another one to have as a primary or backup. I help out around 50 people so I need decent providers.
with the current state of affairs anyone that has a private provider should just keep that private as alot of these public cheap iptv users are having problems with url leakingā¦to those i invited to my private site? best to not invite anyone right now or maybe ever? if one of us messes up? done for all?
I hear that. I came from a private but they were not good. Buffering all the time and channels going down during sports.
Iām just curious if they are truly private URLās now. Guess we will never know.
Thanks Mike. My non-working ā.ruā didnāt have the ā-cloudā in it. Works great now.
I havebeen trying Strong for past 2 weeks, but it seems every 3 or so days I need to contact her to get a new accress to enter. I did not have this issue with other provider. Any ideas, and or a more consistent option?
