šŸ„‡ Best IPTV in April 2026 - Wholesale $2/mo & Alternative
UPDATE UPDATE UPDATE UPDATE UPDATE UPDATE
In the past few days I have been reporting that 8ch-tee-tee-pee://tv.business-cloud-8k.su (instead of .ru) also worked, but now IT DOES NOT
(8ch-tee-tee-pee = http…see what I did there? :smirking_face:)
. Do NOT use .su now for amber strong.
The Whirlwind of Changes shall not prevent me from watching what I want, when I want, all without being tied down and at the mercy of some rip-off cable company. Cord-Cutters UNITE &
1 other potential trip up with URLs you get on a phone through Telegram, Signal, What’s App is that if the URL jumps ā€œdownā€ to the next line, a device often adds a ā€œhyphenā€ that most likely doesn’t exist. I’ve also seen ā€œperiodsā€ added that don’t exist so if you see a potential hyphen or period that looks out of place, try it without it and see if it helps.
Is anyone currently experiencing any errors with Amber?
@Alillio Yes, my Strong appears to be crapping out. It’s a backup and I don’t care enough to monkey with the URL. It usually comes back in a day or 2.
working fine here
I’m on my second url….
@Comtech With all the different URLs she has, I imagine YOURS can be UP and MINE down if you have a good URL and I don’t.
I’m having the same problems with Mega the last couple days.I have not had many problems with it the last year. Channels not working or buffering and not coming on…etc. Amber told me to try the second URL and it’s a little better. My subscription ends in 4 days. I was thinking of trying another one of Amber’s services, maybe Strong 8k or Trex?
Thank you :folded_hands: :blush:
Thanks. Mine went down today. The 2nd one on your list worked for me.
@LadyVersysryder Strong and Trex are EXCELLENT if the URLs are not crapping out on you. It’s REALLY frustrating that this keeps happening.
Yes, very frustrating to have to change the URL at times. It’s easy but still a pain! I’ll have to get a trial for Strong 8k and Trex to see how they are.
I think most of the issues have been resolved. Some channels may still be having issues.
Yes, it seems to be working better now but some of the channels are definitely not working.
@LadyVersysryder TREX has a ton of catchup and great Canada/UK service and EPG works better than Strong with minimal effort. Strong is their most popular I THINK and is a great service when it works. I have Strong now but may evolve to Trex when Strong expires.
I sent you a PM.
I have strong which I just got working again thanks to this site and have taken out a sub for trex. I like the 24/7 channels the best and can say so far I am liking trex better due to the fact that being aā€trekkieā€ I can get all of the series with trex but only a couple with strong.
Thanks for the info. 2nd URL worked for me.
I’m a Strong8k member with a reseller account. I noticed today my services dropped. Amber’s Telegram is gone (unless she’s going under another TG account) and her re-seller platform is down. I sent her a message on WhatsApp but nothing so far (prob because of the time difference between my location in N.America and hers).
In the meantime, anyone have an updated URL to the re-seller platform?
All 3 URLs for my 5 accounts are down. I sent Amber a message yesterday with a reply ā€œthank you my dear friend.ā€ I don’t know if she was thanking me for the money or the notification.
