Best Addon for watching tv shows
@tgm
You are welcome, Syncler is a bit of a learning curve.
o ← letter 0<— number
Yes it is, I am watching Utube with the English guy and he is going way to fast for me, but Like you said there is a steep learning curve but it sure looks it will be worth it
Thanks again for all the help, and I am glad that I found you
Hi, tgm
I’ve also had that same problem!!
Almost pulled my hair out untill I finally was able to figure out that: 0 (number zero) and O (the letter O) appeared exactly the Same while inputting a password or login!
Same with the capital “I” - (as in “I” am…?) and with the small letter “l” - (“L” small latter)
Just wanted to let you know I went :crazy_face: until finally figuring it out!! :sweat_smile::rofl::joy::wave:
@tgm
I recommend mx player or vlc to be set as your player.
Settings:
Source filtering<Filter out by quality. You can edit things like cam 3d 4k unkown… so it only picks what you select.
Content: Enable everything in there if you have a debird service. (Must do this for paid service)
Source resolving: Take off auto play: Dont let it pick for you, you pick.
Those settings for your paid service with s+ are important. I may make a topic covering this at some point, its the best expereince for paid users. its what i do.
You can still use kodi for your tv shows i was just suggesting this. Not trying to lead you to off topic conversation. You can msg me about syncler anytime. lets keep this topic about Kodi currently.
I will msg you with any help with syncler.
I just set MX as player and I am just about done setting it up and i had already set up what you suggested so I feel good that i was on right track and I am sure I can use your help using this app
is this forum set up so you can send private messages to people? if it does not I think I will set up new topic about how to use the Syncler app and the setting to use, if there is not one set up yet and I will let you know, or if you want to do it just let me know and I will follow you there.
By the way, where are you located? I am just out side Chicago in Indiana
Click anyones avitar and a PM message link, along with other stuff will open for you.
I am on last thing i have to do and that is install the express package, I entered the code and then it took me to a page that says enter the urls
Ok what do I do? help Dracoo
I tried adding Numbers but the repo used in the “how to add” post doesn’t have Numbers listed. How did u add it?
