Me too. On both BeeTV and FilmPlus(?!)
It’s really a puzzle to me, the kodi add-ons work fine with rd but the apks don’t for me, I’ll try some of the others mentioned here, Thanks.
Try NOVA adds are still being blocked with CleanWeb.
Ads are not a problem when within reason, it’s the real abusers like pluto tv, that makes me look for ad free, seems like there’s 4 minutes of ads for every 10 minutes of the program, not 4 minutes then 10 minutes, 4 out of the 10, 40%, can’t deal with that much. It’s strange, one of the youtubes I tried to use had long ads about every 2 minutes, then I had a youtube that only made me watch 5 seconds at a time, which is very reasonable.
Wondering which is best adguard, cleanweb or something else?
So rd doesn’t work with this one, correct? And does onstream and flixvision work with rd or is it able to use with both non rd and rd or just non rd? Only need ones that work with rd. Thanks.
Try watching HDO
Yeah you would think but this app is still extremely popular still a ton of people on it IDK why. I don’t use any of the film+ or beetv apps but there are still so many that still use it on regular basis. Only free apps I use is Kodi, cinema HD, sportsfire, ola TV and flixvision. None of them have ads.
Interesting. I use Filmplus with clean web and don’t get any ads. And I’m always updating to get the latest links.
bee tv v 3.7.8 rd links show up, choose a link, gives option of two players, pick either, acts like player loads but never plays the link, will not play the non-debrid link either.
Flix F Vision works with RD. As a matter of fact you can configure it to only use RD links.
Thanks, will try that next, just tried film+ v 1.9.7 did the same as bee, pick link it just sits there, does nothing.
For flix vision, did you get google play protect warning that this app is fake it tries to take over your devise or steal your data warning?
Nope not at all and I ran it through a deep Malwarebytes scan with no issues. Oh but in all fairness I should mention I have Play Protect turned off.
Ok, that sounds right, I think play protect will probably give that warning on most anything not from their store. Just tried tea v 10.7.8r, did the same as bee and film+, just sits there after clicking link.
Thanks Miki, it works, think I’ll have to dump those others, just can not make them work.
Wonder why caribs and scwd3 are both using the same cleanweb but getting very different results? do you think there’s a difference in streaming devices? It’s a mystery indeed. Just tried film+ official release 1.9.7, says install player, clicked it, it said problem parsing package. Are there any of these that will let me use my own player? Thanks.
I got the same warning on my Android box and phone trying to download Flix Vision
Think you have to turn off play protect as Miki said.
Use Downloader with code 11946 to get APKTime. From there go to entertainment and you can download official versions of streaming apps pretty much up to date.
