BBC iPlayer - discontinued on some devices
I did not see anything on this but I just got notification that my firetv bbc iplayer app will be discontinued on sept 30th. They link to a website to talk about it. Im think because of how I got it. It happening to shield users too. Cant remember rule on links but I can post later too
This policy is by the BBC, they are going to stop support for older devices.
Guess Jeff will stop support as well because he needs to sell his new vega os devices
Yeah, I was just curious if others saw this. I had to side load mine due to not being able to find the app in the store.
Or they are building it for vegaos only..
Can always get it through your browser
Using a firetv so I’ll look into it
It seems the website does not allow you to watch older shows only live?
Anyone else getting the message on iPlayer that says the current version will no longer work from November 12? Anyone figured out what to do to get rid of the message, such as update, reinstall, etc?
I’m currently watching using an Onn 4K Pro.
I’d sure hate to lose iPlayer as it’s my most frequent streamer :frowning:
You need to update to .0.9.0 I think.. i’m on a old dev version and trying to figure it out too
I found one workaround which is to move your Google home to the uk so you can then access the uk playstore. But, to do this, you need a uk card for any payments and you can only change location every 12 months so any present home activity is lost.
Let’s keep in touch.
I finally got it!
Here’s what to do:
Completely uninstall iplayer
Go to TechDoctorUK – FireStick Tips, Tutorials & Streaming Guides
Scroll down to the iplayer options and choose the one for uncertified boxes
Download as for any other app
Connect to the uk via your vpn
Open the iplayer app
Login using the QR code
Et voila!
Good luck.
