I thought that I had asked this question a few days ago, but can’t find it. I even posted an image of the audio window.
On every video I watch, the volume amplifier is 0, before I have to adjust it. The box at the bottom is not active where it says to use this setting for all videos.
Not sure what you are asking. What device? What app?
Agreed. I’m not really understanding what your question is. However, and I could be mistaken, I think if passthrough is on then these settings won’t matter. In any case, only use the amplification if this particular app yields lower volume than all the rest of your apps. It’s only meant to normalize volume levels so you don’t have to use your remote to turn the volume up and down every time you switch apps.
