What is TV One Version 1, Version 2, Version 3?? they each require you to do an add on. Where can I find information about choices of these? Swiftstream usa says error check log??
I’m not sure to be honest. I believe those addons host UK TV. I’m in the states . Maybe do a search on here and troypoint.com . Or if someone from the UK here on the insider can help that would be great.
Pete
I am in the states also. I did add the addon on the TV section 1 but don’t want to add anymore unless I know something about what I am doing…thank you for your input! There were other countries plus the usa to access from the add on
Maybe do a Google search or YouTube search. Hope you find your answers soon
Pete
TV One is an African American owned TV station that specializes in Black culture. The app should be available on the Play store.
Asgard add on in live tv section?
Don’t know what you are asking?
The original post about Asgard live tv section options…listed above
To be honest with you id stay away from free live tv options they ether work or dont. Its up and down. Id look into a provider.
I agree with you 100% …you get what you pay for and you can’t get a refund
HaHa! I know! I have an antenna installed in the attic for local channels but it is sometimes iffy (weather related).
