Should I update to 19.3? Are there known issues?
Thanks,
Pete
Thanks,
Pete
I’m running 19.3 in linux as well as Android. So far haven’t come across any insurmountable issues, at least not yet.
Newly installed Kodi 19.3
Troypoint Supercharge Guide installation
Streaming device: Amazon Fire Stick 4k.
ISSUE:
The initial set up path address is different from TroyPoint video guide; input updated address path but noticed through the installation the zip file used appeared to use “diggz” rather than “grump repo” and although I completed the step by step guide, afterwards I experienced multiple issues with the restart and program updates; and Kodi woud not launch or and when it did it would freeze and I noticed that the Fire Stick 4k menu of apps on the home page were no longer visible and although after re-starting the Fire Stick apps would temporarily reappear and work except during activation of Kodi then the issues would repeat.
Please help.
Regards.
