I have two firesticks. One is 4K (Kodi 18)other one is 4K Max (Kodi 19). Both are on same tv with no problem until about an hour and a half ago. Movie would not advance correctly. Then stream would not load/play. Changed addon (s) still had problem getting movie to play on Seren,The Crew, Oath. Restarted Kodi, no help. Changed to other firestick still having problems. BTW when Kodi 18 loads there is a box/message? that says PVR clients: ARGUS TV client Add-on couldn’t be loaded. An unknown error has occurred…
The only issue I’m aware of is with The Oathe on KODI 19. A Dev in a build Group I use was saying that the Oathe Dev was doing an update that broke the Addon but only for a short time and the issue has been fixed. and everyone using that Addon should be good again
Everything seems to be working today…strange!
