Android CPU heat buildup solution
I had overheating problems while streaming with my tv android box. The processor was getting temps up to 65 - 70 (celcius) and cooked the unit. When I got a replacement the first thing I did was to order and mount a usb cooler fan under the box. What a difference! The processor now runs between 40 - 50 degrees with no overheating. If you have a box you really like and want it to last, get a cooling fan. They are available on Amazon for a very reasonable price.
What model did you get at Amazon? Send a name or link. Thanks
Coolerguys cooler fan with USB connector. You can plug it right into any usb port on your android box to power it.
Thanks, I just ordered one.
