To make a long story short I installed the skin after removing a build that I had installed that was causing me several issues.
The skin works for everything except IPTV guide I can’t scroll with the mouse wheel.
I’ve tried other customizable skins and nothing is as customizable the way I wanted is the skin is so I want to stick with it that being said when I’m in bed watching TV I use a wireless mouse for all my settings don’t use keyboard unless I really need to I can’t figure out how to enable the scroll wheel if somebody can help me out I would greatly appreciate it.
Thank you
Or a very good customizable skin if there is no fix I was looking at the xml for the skin I would just need to know what line to add to make the scroll bar work.
