When adding storage and plugging in a thumb drive to the 3rd generation cube. Do I still need to partition that in order to record off of TV mate?
Format your drive first with FAT32 and then you can either set it up for internal or external. You want TiVimate left on the system and any other app that you need to access a lot of resources such as Kodi. You’ll probably want to set it up for internal unless you’re going to record and take it with you. There’s tutorials on troypoint.com if you need.
Oh one quick note. I know some were having problems with added storage and after doing some research if you do have problems then be sure to turn off ADB debugging before setting it up.
