I cannot get this app to install. I have sideloaded all my other apps
Should be able to use the rapid app installer install unlinked and password 12341234 and the pro version is there.
What is happening when you try.
It downloads but does not install
So after it downloads, and I click install, when it gives the install failed error, I click it again is what you’re saying i should do?
You never mentioned an error. But after you select download you will see launch, it should install after you hit that.
If there is an error it usually means it’s already installed.
Actually I didn’t have it but I found it in the amazon appstore and downloaded it. Didn’t know that amazon had it now.
That works, but you will need the codec for it or you will have audio issues on some playback.
I have a topic on this for all the guides for cinemahd.
oh i got the codec. thanks
