4K Live IPTV Review - 15,000 Channels & 100,000 Movies/Shows
Doesn’t work with surf shark for me either
I was just looking at trying this provider hoping to find something that offers more full 1080 HD channels than I currently have and some 4K if possible. Sounds like this one doesn’t have really much of either and it’s more of marketing ploy. Any current users want to chime in if that’s correct?
Many of these Chinese marketed services call the service 4k or 8k and have very few 4k channels. So true!
I had a free trial with 4K Live and for the most part it worked really well. I really only wanted IPTV for one channel and that one channel had about a 40 second audio sync issue. I contacted them and they said they would look into it but later said everything was fine. I tried at least 150 channels and they were all fine except the one I needed. (I was using Strong VPN).
So I moved on and tried a different service that has been working great.
U get what you pay for…it is that easy.get of the ones who have the www,they are bad,get on the ones underground :+1:
New to the patron, I joined because I am looking to replace my IPTV. I have 4Klive now and the guide doesn’t work. I have read through this thread. Which one do you all go with that is fairly reliable? I see a Micheal Wu and Amber baby, but as with everything in life some say they are great and others say they are not.
Thank you.
Test both as they will give you a 24 hour test
As said above, ask for a trial and see what works for you. I recommend Amber Baby and StrongTV as a place to start. Be sure to chat and not just use the normal checkout.
If you do go with Strong, I would recommend this EPG to fill out your guide. You just add it as an EPG source in Tivimate and then assign it to your StrongTV playlist, no individual setup is required. There is a paid version but the free works fine for most depending on what you watch. They do make you “checkout” even for the free plan so you can have a unique id to prevent abuse. If you have any problems jump on their Telegram group. They have a T-Rex guide also, but I haven’t tried it. (Yet).
https://myepg.top/product/free-strong8k-epg/
The free epg is updated every 24 hours, does not provide support, the TV guide will only be available for major channels, and usage is limited to 1 ip address every 24 hours.
The paid epg is updated every 15 minutes, you have the option to request missing channels and access direct support, the TV guide will be available for more channels, and the ip address limit increases to 5 ip addresses every 24 hours.
There are other EGG options if that doesn’t work for you or you don’t want to pay.
https://www.open-epg.com/ They do ask for donations.
I’m not sure what 4kLive is based off of but you may be able to find/make your own supplemental guide or use one of the above.
Good Luck
I have tried about everything, support tells me this and then says it is working just fine as the show a video clip of it working for them.
Sir, the guide service is not available from the channel source and the problem is not with us
When the EPG is available from the source channel it clears up.
I have a month left not that I use it anymore, summer may come soon and the TV won’t get much use.
It do just have to use a different country
Does anyone know if 4kliveiptv has shutdown? My service has been down for over 9 hrs. Customer service has not answer my contact about estimated return of service.
Thanks
I checked 3 sites that report outages and all indicate 4klive is up and running.
Support service seems to be up as is the site and responding without problems. I suggest doing a complete power cycle on everything and reboot your modem.
Can you say what the 3 sites are? Kemo/Lemo seems to be out all day. Curious what the sites say about that.
For the ones closest to you do an internet search for internet down detector or search for “Is lemo IPTV down”. That brings up results for ones that cover your area or country.
i have this service i often have to switch surfshark settings around to get it working
Finally had a free minute. Here ya go. Just one example. I use the duckduckgo search.
Cool. Didn’t know about that one. Looks like the Kemo reseller I was using had one of their servers go down (or taken down). But was able to switch over to another one.
